Sandy Bridge and tri channel memory.
you could run three sticks but they would run in single channel mode
there is no difference between the actual memory in dual and tri-channel kits but Sandy bridge only supports single or dual channel configurations.
Ah but I have only got 3x2GB so I'd be back to 4GB.
Andi.
Aye, running it at 2x2GB would be the best option as you would preserve dual channel mode.
If you want more than 4GB RAM, you could find a single RAM stick of the same (or similar) type to the current three - then run all four in 4x2GB, which also allows dual channel mode.
