- 18 Mar 2011
- East London.
So im looking to build myself a system based around a sandy bridge 'k' cpu - most probably the i5.
I would use it with the onboard HD3000 graphics as it will not be used for gaming.
I plan to add 1 SSD and 1 slim slot type blu ray optical drive. I would also use onboard lan and sound.
What would be a sensible PSU for the above?
If i overclock, then what PSU would be suitable?
I plan on doing a mini itx build but the two problems i think i face in this form factor are the psu and heat dissapation for said form factor.
Pico psu's - would the be suitable and what spec would i need?
Heat - how much heat does an overclocked i5 generate?
(btw, i dont plan on using this pc to run strenuous applications, it will be an everyday use pc but the requirement is that it be the fastest and smallest possible pc that we can build - im open to other specs too)
Thanks
Thanks
