Sandybridge-E or Haswell
20 Jun 2013
Hi guys, I've been out of touch with pc tech for a while. After a lot of moving around and a change of circumstances I find myself back in the UK in Hull of all places
And my faithfull old i5 760 after years of abuse is finally giving up the ghost. I picked up a Gtx 770 and a stonking 1050w psu.
The problem is I find myself stuck between going for the 1150 socket and the older 2011.
Ideally I'd like to oc the danglies off the cpu and not worry about upgrading for a while.
Cheers for any advice, suggestions and reasons
Sandybridge-E meaning Enthusiast will give you more pci lanes for multiple gpu setup and quad channel memory but comes at a cost.
While haswell the latest Intel cpu has a total of 16 lanes that will run 2 gpus at x8 x8 dual channel memory native sata 6gb.
You have a few options The first has 6 cores 12 threads , the other 2 are quad core.
YOUR BASKET
1 x Super Nova ROG Intel Core i7 3930K 3.20GHz @ 4.40GHz DDR3 Overclocked Bundle £1049.99
1 x Standard Build Systems - Approximately 5-7 working days £0
1 x "X79 SPEC OPS" Intel Core i7 3820 3.60GHz @ 4.50GHz Overclocked Bundle £699.95
1 x "Quasar 270i" Intel Core i7 4770K @ 4.5GHz Overclocked Haswell Gaming PC Bundle £619.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLAD38G2133HC11ADC01) £71.99
Total : £2,454.52 (includes shipping : £10.50).
haswell can do 4 way sli, in native pcie 3. unlike sb-e which is kinda iffy by all reports. so thats not an issue.
unless you really want the top end multithreading rendering etc. then get haswell.
I'll probably go for a Sandybridge-E, thanks for the info, now to figure out a decent mobo.
I know the flagship for Asus atm is the Rive, but anyone have any suggestions experiences with other boards
