Hi,
Built my 2500K + Asus P8p67 pro 2*2g corsair xms3 rig today.
It will not post. It has never posted. No beep. No video. No bios.
Green power led is lit. Cpu fan, gpu fan and chassis fan spin up ok.
Cpu led remains lit constantly. According to the manual this points to a cpu problem. I have inspected the socket pins. No damage as far as I can see. Inspected the chip. No visible problem.
Measured all voltages with a voltmeter. All motherboard voltages are present.
Tried to boot with a single ddr3 stick. Same symptom.
It has been a few years since I did a build. Have I overlooked something?
Thanks for your help.
good on you and glad you are now running
