20 Nov 2011 at 11:32 #1 delpy8 delpy8 Soldato Joined 7 Jan 2010 Posts 5,112 Location Up NORTH Hi all, Can i use the below on p67/z68 boards with no issues as its 1.65 memory - KHX1600C9D3B1K2/8GX 16GB Kingston HyperX blu (4x4GB) DDR3 1600MHz 9-9-9-27 Quad Channel
20 Nov 2011 at 12:07 #2 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,567 This stuff - link If so you should find that you'll be able to run it sub 1.58V which is within tolerance for a clocked SB setup.
20 Nov 2011 at 12:33 #3 delpy8 delpy8 Soldato OP Joined 7 Jan 2010 Posts 5,112 Location Up NORTH Plec said: This stuff - link If so you should find that you'll be able to run it sub 1.58V which is within tolerance for a clocked SB setup. Click to expand... Cheers
