Hi all,
Brand new build. Motherboard is a P8P67 PRO (B2 - doesn't bother me) and CPU is a 2500k. CPU cooler is a noctua d14.
Was trying to get a steady 4.5ghz overclock on the default bios that came with the mobo, but I had to set it 1.32v manual vcore for it to run stable. Prime 95 with no errors. However, idle voltage, as reported in cpuz and hwmonitor, was 1.32 at idle and 1.26 at 4.5ghz. Idle temps were about 27/28deg c and load was about 48 deg c. I was confused as to why vcore was higher at idle. Before the oc idle vcore was lower than load. I therefore decided to get the new bios to see if it would remedy the problem, but it hasn't, and at the same vcore prime 95 fails within 15 seconds. I am lost, and I dont want to start pushing over the top voltages for 4.5ghz when I don't believe it is necessary. Can anyone tell me what I am doing wrong, or provide me with settings that they know work well? Is what I am getting normal? Doesn't sound like it is. What should I be setting as LLC?
Thanks for your help.
(havn't tried lower than 1.27 yet). Ram was the issue, failed memtest at 1600mhz. Will try fiddling with ram voltage tommorrow, or slacking the timings slightly.
