Sanity check please
12 Sep 2005
Grundisburgh
Power supply is way over specced for a single gpu system.
As for ram, I suppose you'd have to look into the softwares requirements, and if it will utilise more than 16gb, I'd hazard it could so I'd go for a lower power psu and put the money saved into a 32gb ram kit.
That cooler is pretty pricey too, are you going to be overclocking it to the limits? If not I'd go with something cheaper.
Potential for second GPU later (850W EVGA is more expensive atm).
I'll look at other AIO's and RAM.
cheers.
Andi.
I wouldn't buy the EVGA G1. It's a FSP built unit and not as good as the Superflower units which is why it's cheaper. It also only has a 5 year warranty compared to the Superflower built G2 and G3 units 10 years. I would either go for the cheaper Corsair RM850x, EVGA Supernova G3 850w or pay the extra tenner for the Corsair RM1000x or £15 for the EVGA Supernova G3 1000w all of which have 10 year warranties and are better psu's.
