saphire 5830 black and white vertical lines crash
18 May 2011
hi guys
the last 2 days ive been getting black and white vertical lines when i play any game
the pc will just lock up completely for 10 seconds while this is on the screen
https://picasaweb.google.com/111389206801634542686/BlackAndWhiteLines#5627862551684427362
then it will restart itself
all temps etc are fine
EDIT
thats not my picture but its exactly the same thing as mine does
ive reseated the card also and the problem remains
any ideas
amd phenom II x4 955 be
Corsair XMS3 8gb ram
BeQuiet Pure Power L7 530W '80 Plus' Power Supply
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard
im using the latest drivers
and no, the card isnt overclocked. i was thinking about doing it the other day but im glad i didnt now lol
hmmmm
that mobo features onboard graphics does it not? have you tried running games with just the board gfx?
if not, then it sounds and looks like you have a bad card, do you have another machine to try it in? or a spare card to try?
don't think formatting your HDD would do much, how old is the card, i'd get in contact with the company or manufacturer to arrange RMA personally :)
RMA it then, where did you buy it? if here, you can RMA through Ocuk for the first year if memory serves, after that it has to be with the manufacturers :)
