Hi all, just need a bit of advice on my gpu temps, the pics below are at an ambient temp of 22 celcius. Have l got a problem? The card has been owned by me from new as part of a system l bought from overclockers. It has never been played with and has always been run at 'default' settings. If it makes any difference l play at 4k 60hz.
The first pic is no load pc at idle and the second is after playing fortnite for 5 minutes. From what l read online these temps are getting a bit high? Sratch the pics as l cant see how to attach them but temps below.
No load/pc idle
GPU Temp 62
Memory junction temp 80
Hot spot temp 72
5 mins load
GPU temp 68
Memory junction temp 82
Hot spot temp 90
After Furmark run
GPU temp 70
Memory junction temp 84
Hot spot temp 91
Using HWINFO64, thank you!
No load/pc idle
GPU Temp 62
Hot spot temp 72
5 mins load
GPU temp 68
Hot spot temp 90
After Furmark run
GPU temp 70
Hot spot temp 91
