Just adding this in case you don't catch it later.Bennah said:You can't run 2 ATi cards on a SLI motherboard.
Good point, lol.benjo said:Also, the X800GTO must be PCI-e to be able to crossfire... but i think theres only pci-e crossfire motherboards so it wouldnt work anyway
Yes, Crossfire is PCI-E only.
The X850 mastercards will work with X800 GTOs though, they underclock to the same speeds etc. to match the difference.I thought that was X1300 and X1600 cards only.Gashman said:there is a sapphire X800 crossfire edition, and as well i don't think GTOs need crossfire mastercard to run in crossfire mode, i have heard of HIS X800GTO running XFire without any master, and you definately don't need one according to ATI on new 3200 Xpress boards
Cool.Gashman said:thats one of the biggest features of new chipset, mastercard-less crossfire or so they claim, and as for GTOs they just seem to work for some reason, like X1600s
Anyone want a fantastic overclocking GTO²?
*That's because the GTO fits there, unless you were one of the lucky ones who got to unlock a Connect3D GTO. The GTO² was the one that unlocked to X850 XT PE speeds.FatRakoon said:The GTO and it still no better than any of my AMDs, some running 9800Pro, and one a 6600GT, and was way slower than the 6800GT in the barton.
Exsomnis said:That's because the GTO fits there, unless you were one of the lucky ones who got to unlock a Connect3D GTO. The GTO² was the one that unlocked to X850 XT PE speeds.![]()
