Sapphire 5850 Boot Problem - Solved
1 Sep 2009
Doncaster
I posted a month or so ago about a boot problem since installing my Sapphire 5850. The problem was that the card did not initialise first time round and the BIOS beeped and then rebooted without problem or intervention (I had to set BIOS to ignore errors).
Since upgrading to my new build the problem has gone so I am confident the issue was with my old motherboard and not the video card.
Andy
Im sure someone else solved it by buying a new mobo as well, does seem to be the older boards having the probs, and ive had none at all, anyway, glad you got it sorted :)
Maybe you could also tell us what motherboard it is you had the problem with? :]
