Hi,
Bit of a baffling issue - had BG3 crash on me, screen went blank and GPU fans went mad. On reboot had issues trying to launch the game and after some faffing about found out device manager was showing an issue with the 7900XTX drivers. Reinstalled - and all ok again.
A few days later - bit of web use and video watching - again, black screen and fans 100%. On reboot, see post screen then same problems.
Then on reboot fans straight away and 5 beeps from pc. Suspect card may have died.....
Tried another card in machine (my old Radeon VII) and windows was corrupted, recovery options wouldn't work. Tried reinstalling and kept on getting into boot loops. Perhaps it's a board issue....... Tried fresh install of w10 and w11, same thing. Tried on both an NVME drive and a SATA drive, clearing them first. Finally managed to get W11 to install after faffing around disabling then re-enabling network card. Installed a few things, tested with the R7 - all ok.
Tried 7900 XTX in my old Intel 4790K system - booted up fine, running benchmarks with no issues.
Put 7900 XTX back in main rig - ok initially, then whilst copying files from a backup (nothing visually stressfull) same thing happened again. Now testing card again in old system and it's benching ok, and R7 is running fine in main rig.
Everything has been running fine on main rig for months since I bought the 7900XTX. Upgraded to W11 a few weeks ago but no issues before.
I've also run a MemTest86 run and no errors detected. Even tried resetting bios even though I have no overclocks etc set.
Bit baffled why it's having this issue in such a specific setup - can't tell if the card is faulty or not, or if it's something else?
Then on reboot fans straight away and 5 beeps from pc. Suspect card may have died..... Tried another card in machine (my old Radeon VII) and windows was corrupted, recovery options wouldn't work. Tried reinstalling and kept on getting into boot loops. Perhaps it's a board issue....... Tried fresh install of w10 and w11, same thing. Tried on both an NVME drive and a SATA drive, clearing them first. Finally managed to get W11 to install after faffing around disabling then re-enabling network card. Installed a few things, tested with the R7 - all ok.
