Hi
I have a Sapphire 7970 OC edition (not GHZ, but with Dual-X cooler.)
Stock settings are:
Core: 1000 MHz
Memory: 1450 MHz
Voltage: 1.175
(Performance profile)
I haven't really spent a lot of time overclocking graphics cards, so I decided to go for it and see what the max overclock for 24/7 use I could get.
I managed:
Core: 1100 MHz
Memory 1625 MHz
Voltage: 1.200
Power: +20%
This was stable in Furmark for at least 15 mins (temps reached 82 degrees C.)
The memory clock seemed to keep going, but that scared me so I left it at 1625 MHz, without losing FPS in Furmark over anything lower.
With the core at 1125 MHz I would get funny lines in Furmark, so I backed it off to 1100 MHz. The same thing happened with a voltage less than 1.2 as well.
Are these reasonable clocks, and is that core voltage ok? How long should Furmark be run to assume a stable overclock?
Or maybe I should use something less harsh than Furmark...
Thanks!
Stock settings are:
Core: 1000 MHz
Memory: 1450 MHz
Voltage: 1.175
I managed:
Core: 1100 MHz
Memory 1625 MHz
Voltage: 1.200
Power: +20%
Thanks!
