Sapphire Active DisplayPort to Dual-Link DVI Adapter Where ?
9 May 2009
hi all i am after another 2 monitors but i need a Sapphire Active DisplayPort to Dual-Link DVI Adapter and i can not find these at all in stock on OCUK or othere sites.
is there a problem with these devices and been put on hold as i have been wating 4 weeks now.
any help thanks
thanks but what are the dell ones like and why are the sapphire ones not comming into stock
the dell version says it supports up to 1920x1200 but i want to use eyefinity which is 5760x1200
and the sapphire version Supports Dual-Link DVI resolutions up to 2560x1600
It means 1920x1200 on one of your monitors, which is the one going though the adapter. This effectively means you'll still get 5760x1200 in eyefinity.
