** SAPPHIRE CUSTOM 290's ARE ON THE WAY!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK has secured the first waves of the Sapphire custom cooled 290's, seem they are using their Toxic cooler, so performance, low temperatures and low noise pretty much guaranteed, check these bad boys out.
All confirmed as including BF4 as well, ETA middle of January. :)
Sapphire Radeon R9 290 Tri-X "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 1000MHz
- Memory Speed: 5200Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £379.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Tri-X "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £489.95 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
Only £489.95 inc VAT.
ORDER NOW
OcUK is King at bringing you custom 290's before any other Etailor in the UK and we have secured the first waves of stock from most board partners. :)
Because I don't think they are full fat toxic cards.
they only have 8+6 pin connectors which if it were a proper toxic card it should have 8+8 minimum as thats what the 280 uses and the 290 cards use more power.
Since power supplies which have 8 pin connectors actually give you a 6 pin with optional 2 pin it seems like a moot point to have a 6 or 8 pin connection on the card since its the same cable with the same current capacity.
When 6-pin are in use it supplies upto 75W. When using all 8-pin upto 150W can be delivered.
