Sapphire HD4870
6 Oct 2004
Southampton, UK
Hiya
What is the actual length of the Sapphire HD4870 card ?
i was just wondering if it is exactly the same as the Sapphire HD3870 , as that card is a bit of a squeeze fitting into my case.
I plan to get one soon , or if the HD4870 is longer in length , ill get the HD4850
Cheers in advance
Lusty
Cheers :)
PSU shouldnt be a problem as i have an Enermax Liberty 620W anyways.
I just need to know if the card will fit within my current set up thats all.
I dont want to get the card and then mess about too much with the case etc etc.
Lusty
it's not that huge.. about a half inch longer than my old x1950pro.
I have a gigabyte 4870, which seems to have a very similar cooler to the sapphire one - the pci molex's are squished against the hard drive cage in my thermaltake armour jr :/
What case do you have?
I have a Silverstone TJ-04
My current Sapphire 3870 fits in just , but makes the top 2 slots in the hard drive rack un-useable. The power plugs are sticking out from the back and prefer them to be on the top.
Lusty
