So after some experimentation and checking I've narrowed down that poor performance of my new R9 (based against an old HD6870) seems to be due to the GPU (rated at 1010Mhz) bouncing between 300Mhz & no more than 800Mhz.
This coincides with stuttering and fluctuations in FPS. I am have tried 15.12 and now the 16.1 hotfix crimson drivers...still the same.
I'm using MSI afterburner to keep the fans at around 65% and the temp is going above 55C.
Is there a way I can force the card to run the GPU at a stable 1010Hmz? I can't seem to find a way to do it.
Cheers
Cheers
