Sapphire R9 390 Thermal Pads/Paste?
20 Jan 2016
Scotland
Hey,
just wondering if anyone has any idea what thermal pads and thermal paste would be a good upgrade for this graphics card?
currently on idle it sits at 35-40C with GPU Fan speeds at a constant 35% (not auto mode) I found auto mode SUCKED and would rev the fans up and down from 20% to 65% instead of keeping the temperature constant.
on full load in most games the temp rises to 65C with GPU fan speeds around the 55-60% mark, if on auto mode however the temp rises to 70C+ with GPU fans at 40%
Should note that the intake fans are at full RPM when gaming and lowest speed possible when idle and the exhaust fans - push-pull radiator fans running at 50-60% speed gaming 1600RPM, 30-40% idle - 900-1100RPM
Although that sounds OK for this graphics card there has been the rare occasion when the temperature on idle has spiked to 80C when I boot up the crimson software though it does lower again, which of course got me worried that perhaps the paste and/or the thermal pads haven't been applied correctly.
I've been hunting and googling galore and reckon I'll go with arctic mx-4 paste though some advice would still be nice - I haven't ever really replaced thermal pads before or had too so that's the main area of concern. :confused:
Help appreciated :D
The temp spikes are almost certainly a software bug and nothing to worry about. HWMonitor often tells me that my gpu reaches 255C which I know for certain it isn't.
New thermal pads won't affect core temp.
Hey,
Help appreciated :D
I wouldn't spend a penny on it. 390's and 390's are hot running GPU's, almost impossible to keep them under 80DC on air without having the fans at a deafening setting. Nothing you can fit/change on the card will reduce the immense amount of heat it outputs.
It's worth remembering Hawaii GPU's (290, 390 series) are all designed for 92°C+, so 80°C is a very safe temperature for these cards. Nothing to be worried about at all.
I'd enjoy it's performance for now and then upgrade to a 16/14nm GPU when you feel it's time.
cheers for the response + advice, I've heard that these cards can run hot and were designed to withstand such temperatures but it's still nice to try avoid those temperatures.
