Sapphire Radeon R7 240 1GB DDR3 64-bit or 128-bit Bus?
24 Sep 2014
Hello
I am interested in getting the Sapphire R7 240 with 1GB DDR3 as it is pretty cheap, however I get different information on the bus being listed as 64-bit, or 128-bit depending on the site I am looking at. If it is 64-bit, then I'll give it a pass. Does anyone know what bus this card has?
Thanks.
Hello humbug. I was looking at running games like FIFA, and the Racer Driver Grid games, I have a 19inch monitor so I figure this should be OK on medium settings?
Yeah, i'm assuming its 1600x900? it should be ok but i think it would be better if you set the resolution to 1280x720 in game. it should do the job.
It is the lowest end card you can get, if you don't mind spending a bit more a 260X is a much better card for its money, its about twice as fast. http://www.overclockers.co.uk/showproduct.php?prodid=GX-228-MS&groupid=701&catid=56&subcat=1866
