Sapphire RX 5700 XT NITRO+ SPECIAL EDITION owners - Are your fans faulty ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Hi all.
After some feedback from owners of this card regarding the ARGB fans.
History ;
Card 1 : Purchased early Feb this year - Developed faulty fans March 1st
Stuck red rgb on 1 fan
March 6th this had spread to 2 fans and random blinking, at which stage i was advised by Sapphire that it needed RMA as the card itself maybe faulty.
OK, faulty cards happen, so no major issue - i thought :D
Card 2 : I purchased brand new one to avoid RMA delays on March 6th
Yesterday one of the fans started to fail
I am either astronomically unlucky to have 2 develop the same problem, or there is an issue with the cards themselves.
Anyone else having issues with theirs ?
Hi all.
History ;
Can I ask what software you are using to control the fans colours, and are they sync'd with the rest of your PC?
I can check tomorrow for you on mine, at the moment it's running in default mode and no software is loaded on.
Hi, just running the standard TriXX software from Sapphire, so not synced.
You'll need to switch to a static white/yellow colour, as a stuck red rgb won't show on a lot colours.
Would be great to get some feedback from others , thx
UPDATE;
So more rgbs failing now, this is following the pattern of gradual failure in the first card ;
15/4/20 - random green rgb stuck ( doesn't show up well in photo )
Today 19/4/20 ; random Blue rgb next to the green one
