Sapphire RX 6600 XT Nitro+ Searching for ARGB fans!
22 Aug 2010
On the Wagon-East Angular
Hi all - I've got a Sapphire RX 6600 XT Nitro+ GPU and I'd like to fit some argb fans to it to tie in with the rest of my case, but I'm not having much luck. Sapphire do not officially do replacements for the RX 6600 XT
Spec wise the model of the 2 fitted fans are CF9010H12D and they are just under 90mm in diameter. The housing they fit into are just over 90mm. There are 6 terminals that connect to the fans, and these appear to have the ARGB connections needed. I'll add some pics below. To add the card has ARGB inputs that I'm currently using so the logo is the same colour scheme as the rest of my build, and I was hoping to get fans that would also use this argb input.
Any ideas? Pointers gratefully received! Cheers
