Sat Nav Input required
18 Oct 2002
Manchester
First of all sorry if it has been asked before but you hear all about the Tom Tom range of Sat Navs but what I want to know if you have only a limited budget of @ £160 and just really need a Sat Nav that represents value you for money in that you can add various software to it without it being incompatable ie camera database low high bridges ect etc is there a particualr Sat Nav that someone would recommend. I am looking to purchase an all round system rather than a top of the range all singing all dancing thing.
If anyone could advise a model I would appreciate it
:D
Aldi has their Medion branded satnavs on special offer for £149. Effectively it's a PDA with rebranded Navigon software, which is pretty decent for the price.
So is Tom Tom the only option then peep? What about the Garmins etc etc Is it all hype with Tom Tom or is it like Windows they have cornered the market even though the actual product isnt all that good.
Get yourself a GPS receiver and you can get Tomtom on your phone. Does depend on your phone mind.
I have Tomtom on my o2 XDA Mini S. Works identically to a standalone unit.
Garmin I3 TBH. 99 quid from the high street rather than £200+ for Tomtom that does the exact same thing but has a bit of "brand awareness" thrown at it IMO.
Tried both, bought the Garmin for the missus as there was nothing in it except the price
I flogged one or two Garmin i3's on ebay.. they are excellent value for money, and are worth considering, especially since they can be picked up for £99, as mentioned..
However, the TOMTOM ONE for example, is a much better product, that's not to say the i3 is rubbish, but it does have one or two small limitations.
1. The GPS Chipset is distinctly average, it can struggle at times to get a lock, and in built up town centres with tall buildings, it can lose the signal a little too easily, you can get an external aerial for it, which would help if this becomes an issue
2. There is no way to just view the map, select a 'spot' that you want to goto and then navigate to it, you can only navigate to postcodes or addresses it has in it's database, This is generally not too much of a problem until you want to go anywhere (usually rural or a business) that the postcode isn't correct/available, and you don't know the 'street number' for it..
3. The screen is very small, but I suppose what do you expect for the money
4. The screen update rate is a little slow, and this can make navigating a set of roundabouts a bit annoying, as it's always catching up with you.
The TOMTOM ONE has the latest GPS Chipset, larger touch screen, with more ways of specifying a destination, it's extremely fast as well..
I originally had an i3, but have upgraded to a TOMTOM ONE, despite having numerous PDA's and smartphones with TOMTOM on them, I just prefer the dedicated units, they can't be buggered up easily, and just work so well..
Know a few that have tried to do it on a budget, ie sub 200 and just regretted it. Seriously save another 50 quid and get a ONE, you would be mad not to.
