SATA Compatibility?
18 Jul 2004
Ive got an old motherboard (bought around 05/06) with a SATA controller in it. Will it be able to take newer SATA hard drives? I see terms like 3/6 GB/s but im not sure if this will work with my motherboard?
So is it worth just getting a non 3/6 Gbits one and saving some money?
Its only going to be used in an HTPC so speed isnt too important.
2tb drives are slow as it is, 3 or 6 it doesnt really matter :)
2TB drives aren't necessarily slow when compared to other HDD's.
If you're comparing to SSD's then that's a different ball game.
I'm sure WD would be upset if you said that their 2TB Black was slow.
And here's a benchmark of the Samsung F4 EcoGreen:
Quite respectable for a HDD.
On a related question, for an HTPC can anyone recommend a good internal 2TB hard drive?
I was looking at something like the Samsung Spintpoint F4EG but I noticed some comments claiming it was bad for an HTPC as it would spin up/down during playback causing freezes.
Samsung SpinPoint F4 EcoGreen 2TB!
Quiet and quick (see my post above).
The HDD shouldn't spin down while it's being accessed so I'm not sure where that comes from.
In the advanced power options in Windows you can also set the interval at which HDD's spin down. But as I said they should only do this when idle.
