- 9 Dec 2008
Hey,
I have a SATA drive (which has WinXP Pro installed on it) which I want to connect to a Win2K machine to search the drive for some old files. Getting it running again with the mobo that it used to run with is too much work right now (that mobo which is currently shelved has a water cooling block installed on it... would be a lot of fussing to get that running).
The Win2K machine runs on PATA so I presume there are no SATA drivers available in the OS currently. Does the Win2K install disk come with SATA drivers on it? How in general would installing a SATA drive as a secondary drive work out on a PATA Win2K machine?
This is just a temp arrangement to look for files on the SATA drive. From what I remember the WinXP Pro that's installed on the SATA is not pw protected so I should be able to access all the files.
Thanks
Thanks
