I upgraded from win 8 to 10,and had some issues with getting the black screen after login. Managed to fix it temporarily by unplugging excess drives and monitors for long enough to get it activated, then plugged in my new ssd and did a fresh install on there.
All well and good, windows running fine, except when I plug that old drive in again. For some reason my computer will always chose to boot off that old drive, no matter where it is in the boot order and even when I select it in the boot options during post.
So, my plan b is to keep the power plugged in but then just plug the SATA cable in once I'm already in windows. I've seen lots of posts saying you can do this, and a couple saying you can't, so I just wanted to check here first! The drive in question is a Kingston ssd, and a gigabyte z97x gaming 7. I only want to copy some stuff off it then I'll be formatting it so I can actually boot with it plugged in.
Thanks!
Thanks!
