SATA-II
8 Jan 2007
Cognac, France
I have this mobo - MSI P55-GD65 Intel P55 (Socket 1156) DDR3 Motherboard with Free USB 3.0 PCI Controller Card
Can I fit a sata-II HD in?! :confused:
What do you mean? a sata 2 port hard drive will fit in a sata 2 port. If your meaning plug your sata 2 hard drive into the usb3 port you will need a hard drive enclosure that will take sata 2 drives and plugs into a usb 3 port. For example
http://www.overclockers.co.uk/showproduct.php?prodid=HD-008-SH&groupid=701&catid=14&subcat=72
I just copied the mobo details from my order history, I wasn't specifically asking about USB connection.
I wasn't sure if I could run SATA, SATA2 or SATA3 hard drives. I've had me head in the sand since 2009 regarding latest hardware.
You can run all three as they are all backwards compatible, however the speed will be the same no matter which port you use.
