SATA Installation Question
27 Jan 2004
I have an old PC that has an IDE drive with Windows XP installed on it. When I installed XP I did not install the SATA drivers during setup as I did not have any SATA drives to connect at the time.
Several years down the line I am in a position where I have a SATA drive with data on it that I would like to access using the said old PC.
The motherboard came with drivers to install SATA during XP setup, however I can't find any drivers to retrofit once XP has been installed.
http://www.asrock.com/mb/download.asp?Model=K7VT4A PRO&s=
Is what I'm trying to achieve actually possible without doing a fresh installation of XP on the IDE drive?
Thanks
You shouldn't have to reinstall Windows just to get SATA working. There must be a stand alone installation file for Windows once it's installed. Let me have a look for you. :)
If you just want to grab some off the drive you don't need any drivers, only need drivers if your going to do RAID.
