I've just had a computer re-formatted and Windows XP re-loaded by the local computer shop, normally a task I would do myself but was time limited on this occasion. The computer is a SFF AMD S939 with a 300GB SATA hard drive.
The installation was done whilst I was in the shop. During the install, SATA drivers were not loaded. Last time I did this I had to install a floppy disk which came with the motherboard and press F6 at windows install.
When I questioned this, I was made to look a complete No swearing! in front of the rest of the people in the shop - which is fair enough if I was asking a stupid question.
I've done some further investigation, it would seem that having to load SATA drivers depends on the motherboard, some have on-board SATA drivers.
Two questions:
1) Is my conclusion correct regarding SATA drivers?
2) Why does the the HDD show up as a removable drive in the right hand of the taskbar (systems tray?) as if it was a removable drive, like a memory stick?
In the 'safely remove hardware' screen, the HDD shows up as 'WDC3000 at location 0', location 0 being the primary ATA channel according to device manager.
Two questions:
