sata lead pins
26 Aug 2004
London
I was sleeving my PSU cables and accidentally broke one of the sata pin connector things (the terminator on the end of the cable that goes into the sata power plug) off of it leaving only two pins.
Hopefully this will make it clearer,
I've broken the terminator on the yellow cable.
The question is what are the terminators called? Is it possible to buy them or will I just have to get a molex to SATA converter and use that instead (I've only got to SATA power cables built into my PSU and two SATA HDDs :( )
fini
Are you talking about just buying the black connector itself and soldering it on? It might be possible but I don't know where you would get them and the obvious places didn't help too much so I'd say it was simpler and probably cheaper to just buy a molex-SATA connector. Sorry I can't be of more help.
no not the black connector itself - the bit that goes on the end of the wire that then plugs in to the back of the black connector.
fini
