sata power plugs
If IDC connectors would suit then try Googling '67926-0011'. It's the part number for Molex IDC SATA power plugs. You'd need to get hold of the caps as well, but they're available from the same providers.
In reality IDC is probably the best option unless you have the correct (and v.expensive) crimping tool.
thank you
