- 12 Dec 2006
your oval dish will work well with a multiswitch as it gives higher gain over longer cable runs and switch losses. A ms lnb will cost £13.
Sweet thanks. Sorry to OP for taking slightly off topic![]()
As long as you are careful when replacing to LNB then it should be ok.
You will need to make sure that the LNB that you get is compatible with your model of dish as sky have changed their dishes a few times in recent years and you may find that it wont fit on the end. Any chance of a pic of the dish and LNB and I will be able to tell you which 1 you will need.![]()
that yellow card looks like one of the old analouge sky cards, as sky havent used that logo for years now.
