- 5 Apr 2008
Hi,
I have been having problems getting DVB-S tv to work on media center in both windows 7 and vista.
Windows 7
Compro S500 USB(with vista drivers and no driver signature enforcement)
First channel you press does not work (no signal), change channel and it is fine after that - stops recording though.
Hauppauge Nova-S-USB
Is fine at the beginning but after a while when you change channel there is the same no signal message.
Windows Vista with TV pack.
Both tuners are detected but no satellites are found.
What should i do??? Both tuners are usb and have similar problems in Windows 7. Could that be a problem, should I update the bios?
Windows 7
