- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
Looking for better airflow, nice styling, or just after a bling-bling case. Today we have some tasty deals today on a range of cases.
NZXT Phantom Enthusiast Full Tower Case - White @ £107.99 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £119.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
OCUK EZCool NA-705 Case - Black (500w PSU) @ £20.99 inc VAT
The NA-705 is an entry level range which meets the latest thermal requirements.
- Front Panel-Light up Blue highlight LED
- CPU support: Dual Core
- Driverbay : 3*5.25 external
- 1 x 3.5 external
- 4 x 3.5 internal
- Chassis-1 x80mm rear fan Space: 1 x 80mm front fan space
- Fan Duct
- Compatible M/B : MATX
- Riveted 0.6mm Japanese SECC metal frame in metallic silver PSU- 500w
- Dimensions: 180mm 445mm 410mm (W x D x H)
Was £22.99 Inc. VAT
Only £20.99 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Arctic White @ £92.99 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £99.99 Inc. VAT
Only £92.99 inc VAT.
ORDER NOW
Antec Dark Fleet Series DF85 Gaming Enclosure - Black @ £127.99 inc VAT
Time to build a killer rig? Turn to Antec. The DF-85 is the gaming case re-envisioned, with all the award-winning build quality that made Antec cases famous and plenty of airy, wide-open expandability with 14 total drive bays and 7 expansion slots. Fleet-Release™ front drive bays allow swift customization of front fan and drive configurations and easy access to tool-less, washable fan filters. A top-mounted hot-swappable SATA (SSD-compatible) drive bay plus Fleet-Swap™ SATA drive interfaces offer blazing fast throughput with superb convenience. With pioneering design and world-first conveniences, the Dark Fleet DF-85 is the case of choice for your next flagship.
- Three Fleet-Release™ access doors open separately for convenient entry to drives
- Three washable fan filters allow for easy cleaning
- Top 2.5” hot-swap SATA (SSD-compatible) drive bay
- Bottom-mounted power supply isolates heat
- Mounts either a standard size power supply or an Antec exclusive CP Series power supply
- Lockable access doors ensure security
- CPU cutout allows for easy installation of CPU coolers
- 14 drive bays
- Up to 9 x internal 3.5”
- 3 x external 5.25”
- 4 x external 3.5” Fleet-Swap™ drives (position changeable)
- 1 x external top 2.5” hot-swap SATA drive bay
- 1 x internal bottom-mounted 2.5” SSD drive
- Advanced cooling system
- 2 x top 140mm TwoCool™ fans
- 2 x rear 120mm TwoCool™ red LED fans
- 3 x front 120mm red LED fans with speed control knobs
- 1 x side 120mm fan to cool graphics cards (optional)
- Water cooling capable
- 7 expansion slots to support multiple graphics cards
- Maximum graphics card size: 12.5” / 318 mm
- Cable management ties help keep your case tidier
- Stylish blacked-out interior
- Windowed side panel
- Front ports
- 1 x USB 3.0
- 3 x USB 2.0
- Audio (AC’97 and HDA compatible) In and Out
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Weight: 26.3 lb / 11.3 kg
- Dimensions: 596mm (H) x 213mm (W) x 505mm (D)
Was £139.99 Inc. VAT
Only £127.99 inc VAT.
ORDER NOW
Coolermaster CM-690 II Lite Dominator Case - Black @ £55.99 inc VAT
The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole. This model comes with a great looking window to showcase all your hardware.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
Was £62.99 Inc. VAT
Only £55.99 inc VAT.
ORDER NOW
Coolermaster Elite 430 Windowed Case - Black @ £36.99 inc VAT
The Elite 430 Black was designed all-black interior coating with its main purpose in mind as such there’s plenty space for large graphics cards, no matter your brand preference. The Elite 430 Black also features plenty of cooling options and a well ventilated front mesh design to keep even the hottest system nice and cool.
- Interior black coating makes stylish inside looks
- Front 120mm fan with brilliant Blue LED provides the best airflow to HDDs
- Rear 120mm fan for high-efficiency ventilation
- Tool-Free mechanical design for quick assembly and maintenance
- Side ventilation holes for better cooling performance
- Large transparent side window included
- Supports long graphics cards including Radeon HD 5970
- Top Cooling: 120 mm fan x 2 (optional)
- Front Cooling: 120 mm blue LED fan or 140 mm fan x 1 (optional)
- Rear Cooling: 80/90/120 mm fan x 1(optional) (120mm fan included)
- Side Cooling: 120 mm fan x 1(optional)
- Bottom Cooling: 80/90/120 mm fan x1(optional)
- I/O Port: USB 2.0 x2, Mic x1, Audio x1, 1394a x 1,(optional)
- Dimension: 190 x 424 x 490 mm (W x H x D)
Was £42.99 Inc. VAT
Only £36.99 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £129.98 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Only £129.98 inc VAT.
ORDER NOW
ORDER NOW
- 1 x 3.5 external
- 4 x 3.5 internal
- Fan Duct
Was £22.99 Inc. VAT
ORDER NOW
Was £99.99 Inc. VAT
ORDER NOW
- 14 drive bays
- Front ports
- 1 x USB 3.0
- 3 x USB 2.0
ORDER NOW
- Support Tri-GFXs
Was £62.99 Inc. VAT
ORDER NOW
Was £42.99 Inc. VAT
ORDER NOW
- 12 Drive Bays
- 7 expansion slots
ORDER NOW
