Savage Moon expansion
17 Aug 2008
Surrey, UK
I got this yesterday and so far I can't see it in game... I went onto the store, purchased and downloaded it then went into the game where it said v2 update download, then it went in but no expansion... so went back to the store and redownloaded it and still can't see it. Just wondered if anyone else has had this... was thinking completely remove it and reinstall original, then update, the download add-on to get it working... thoughts?
ta
Similar problem to me then, although after downloading the expansion and then downloading the update, it wouldn't actually let me back into the game, saying I basically didn't have permission. In the end, I deleted the entire game, downloaded it again (as the demo), then downloaded the unlock file again, ran the game, exited and then downloaded the expansion. Works fine now.
I think the problem is caused by downloading the expansion file before having the latest patch installed. The patch is essentially the expansion in its entirety, the actual file for the expansion just unlocks it for you.
I did the same to get mine working.
What do you guys think, seems to be pretty tough so far I have only manged to complete the 1st map after several tries.
I didnt have any probs, downloaded the unlock and entered game and left to find the new maps, i have to agree with paul those new swarm rockets are lethal, even had 2 full repairs towers beside each other and they still werent enough to keep my towers alive
I had to delete the game, re-download it, patch it then install the expansion. Worth it though, the new levels are awesome if VERY frustrating!
Currently upto the 5th which I nearly have sussed. The new Arc towers seem a bit over powered a few of them will take out everything.
I had 5 arc towers with 2 repair towers and a boost tower, all up to lvl 4 and the 1 death blossom came by and destroyed them all, that insectoid is far too powerful, even if 1 gets by with ur base at full its an instant fail.
I scatter mines along their path well away from my base, seems to work.
Up to 4th level but yet to try it.
