Save AutoCompleteCustomSource using My.Settings
20 Jan 2005
Whitley Bay
**VB.NET**
Hi there,
I wonder if anyone can help me:
I use a textbox AutoCompleteCustomSource to save recent entries within a textbox and obviously, then autocomplete them when the user enters a matching value. When the application is closed then re-opened these values are lost.
I believe I can save the values using My.Settings but I haven't been able to get it to work.
I created a setting 'AutoCompleteList' of type System.Windows.Forms.AutoCompleteStringCollection in the Project properties > Settings area.
This allows me to use the code below on the form's load event:
Code:
SearchBox.AutoCompleteCustomSource = My.Settings.AutoCompleteList
and the code below in the form closing event:
Code:
My.Settings.AutoCompleteList.Clear()
My.Settings.AutoCompleteList = SearchBox.AutoCompleteCustomSource
However nothing appears to be saved/loaded. Can anyone point out where I'm going wrong? New to the my.settings area.
Thanks
Si
Edit: Just tested again and I'm actually getting 'Object reference not set to an instance of an object' for the line "My.Settings.AutoCompleteList.Clear()".
