** SAVE BIG WITH OcUK 4K MONITOR & GRAPHICS BUNDLES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got some great bundles for you guys making the move to 4k, with these bundles you can save upto £200 of the price of buying the items separately, even when the items are even on promotion. :eek:
NVIDIA 4K Bundle: GeForce GTX Titan Black & AOC 4k Monitor **£100 SAVING"" @ £1,139.99 inc VAT
This bundles saves you £100 when you buy an MSI GeForce TItan Black 6GB and AOC 4k monitor together.
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 80,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
GeForce ® GTX™ TITAN Black is a masterpiece in design and engineering. Evolved from the award-winning GTX TITAN, the Black edition lets you take on your most graphics-intensive games with 10 percent faster performance, while still retaining whisper-quiet acoustics and cool thermals.
This is the elite gaming GPU for gamers who demand the ultimate pure gaming experience-the perfect balance of sleek design, spectacular performance, and groundbreaking technologies. Power your most extreme games, and even 4K and multiple monitors at 25 x 16, with high-speed double precision and 6 GB of frame buffer memory.
Like the original TITAN, the new TITAN Black edition also includes high-speed double precision for the NVIDIA® CUDA® enthusiast
Specification:-
- GeForce TITAN Black Edition
- Core Base Clock: 941MHz
- Core Boost Clock: 980MHz
- Memory Clock: 7000MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£1239.99] Inc. VAT
Only £1,139.99 inc VAT.
ORDER NOW
NVIDIA 4K Bundle: 2x GeForce GTX Titan Black & AOC 4k Monitor **£200 SAVING"" @ £1,779.97 inc VAT
This bundles saves you £200 when you buy two MSI GeForce TItan Black 6GB and AOC 4k monitor together.
Specification:-
- Panel Type: TN
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Specification:-
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£1979.97] Inc. VAT
Only £1,779.97 inc VAT.
ORDER NOW
AMD 4K Bundle: AMD R9 290X 8GB & AOC 4k Monitor **£100 SAVING"" @ £959.99 inc VAT
This bundles saves you £100 when you buy an Sapphire R9 290X Vapor-X 8GB and AOC 4k monitor together.
Specification:-
- Panel Type: TN
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1060MHz >
- Memory Speed: 5600Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£1059.99] Inc. VAT
Only £959.99 inc VAT.
ORDER NOW
AMD 4K Bundle: 2x AMD R9 290X 8GB & AOC 4k Monitor **£200 SAVING"" @ £1,419.97 inc VAT
This bundles saves you £200 when you buy two Sapphire R9 290X Vapor-X 8GB and AOC 4k monitor together.
Specification:-
- Panel Type: TN
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 2yr
Was [£1619.97] Inc. VAT
Only £1,419.97 inc VAT.
ORDER NOW
These bundles prices are pretty epic!! :D
