Ok, slightly over-dramatic thread title but hey ho
I moved house over the weekend and on Friday I had a working PC as I was listening to music on it whilst doing some final packing. I then boxed up the tower in its original box and it was moved along with all my other crap by a removal company.
Fast forward to Monday and setting up the PC in the new house. I switch everything on and get no video on the TV via HDMI through the av receiver, set up exactly as it was in the old house. Odd..
So, I proceed to try the following.
Several different HDMI cables in both on board and dedicated GPU. With and without the dedicated GPU installed.
Tried clearing CMOS and repeating the above process.
Tried on board VGA with a friends monitor
Tried DVI to HDMI cable from dedicated GPU.
Tried bypassing the AV receiver, straight to TV.
At this point I'm convinced it is not an actual video issue but another component, possibly the motherboard itself or CPU. Bear in mind I get no POST beeps as there is no speaker.
I then try disconnecting everything from the board except CPU and fans and VGA. Still nothing.
When I power on the PC it just stays powered on but does nothing, no beeps, no video, doesn't turn off.
I'm not convinced anything is shorting so have not taken the board out of the case....yet.
My thoughts are that the weight of the CPU cooler has maybe damaged the board and/or CPU in the move and this is the problem.
The board is an ASUS P8Z77-LX2 and the CPU is an i5 2500k.
Has anyone had any similar experiences and is there something I haven't tried that might save me having to buy a new PC or try and source a new CPU and board of the same type?
