Hi Guys
With the launch of the 780Ti, most block manufacturers have reached the point where they are converting their standard 780 block designs over to the new Ti version to make a full cover block that fits every design.
This means that existing Titan and standard 780 users now have the opportunity to grab these excellent XSPC blocks for a fantastic price.
with £25+ off each block, it is ideal for people looking to move to water cooling or for those with standard 780s looking to push towards Ti performance levels!
XSPC Razor GTX 780 & Titan GPU Waterblock **GTX 780 COMPATIBLE** @ £69.95 inc VAT
Full Cover GTX Titan Water-Block with multiport connector.
We are proud to introduce our new design for Razor GPU blocks. We have continued with the styling from our RayStorm series so you can now have a full set of matching XSPC blocks. We have also significantly improved cooling performance by reducing the fin width from 1mm to 0.5mm, this dramatically increases the surface area.
Although we have used an acrylic top for aesthetics we have a thin stainless steel plate between the copper base and the acrylic. This allows us to use LED lighting, while keeping the strength and reliability of an all metal waterblock.
The new multiport connector gives you many choices for neatly routing your tubing. We have two G1/4? ports on the front and back of the block, two on the top, plus a side port, giving 7 ports in total. The multiport connector is compatible with our new SLI flow bridge.
- CNC machined copper base
- 0.5mm fins for high performance
- Stainless steel top
- Acrylic layer with 3mm LED holes
- Brushed aluminium faceplate
- Dimensions: 266.7 x 124.4 x 25mm
- Prepared for SLI with 7 G1/4? ports
- Supports GTX Titan cards
(Nvidia reference design only)
Supplied with twin LED, mounting kit, G1/4" plugs, thermal pads and thermal paste
Was £94.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Was £94.99 Inc. VAT
ORDER NOW
