I saved myself £50 by making a side window in my Lian LI V1000. I can't believe how expensive are all the accessories for the Lian Li. Here is a pic of how it turned out, perfectly straight and smooth edges, used rivets instead of glue or sticky tape. Need to work on the inside of the case a bit more now, planning some UV stuff.
