Saving and accessing documents on iPad?
16 Nov 2002
The Moon
Got a variety of documents that I need to get onto an iPad and will need to keep adding to them as time goes on - stuff like word documents, spreadsheets, powerpoints and videos.
Whats the easiest way of getting them from our PC's onto the tablet itself? Is anyway I can just drag and drop them and then access the files through a file browser on the iPad itself?
Dropbox is a good one, using Open In feature to access files as there isn't actually a native 'file browser' on ios, unless you are jailbroken. Ifunbox is as simple as it gets to drag/drop files from PC directly into ios apps that support file transfer.
Another recommendation for Dropbox. It's also supported by way more iOS apps in comparison to other cloud storage providers.
