Saving JPEG's in PS6
22 Aug 2010
In My Command Center
Dont get me wrong i know how to do it :p but i just wanted to know what are the optimal settings when saving as i have always just hit save.
What does all the format options do?
many thanks buzz
Don't hold me to this, however I think Optimized, helps with the size without doing much damage to the quality, whereas Standard doesn't help with the size at all.
Found this with google:
Baseline (Standard) - This JPEG format is recognized by all Web browsers.
Baseline Optimized - This JPEG format option provides optimized color and slightly better compression. It is supported by all modern browsers, but was not supported in the very earliest of Web browsers. It's your best choice for JPEG files today.
Progressive - Creates a JPEG file that displays gradually as it downloads, starting out blocky, and gradually getting clearer as it downloads. It doesn't make the image download any faster, but it can give the illusion of speed since the blocky image is loaded right away on a slow connection. With the majority of internet users on high speed connections today, Progressive JPEG is rarely used.
spot on thank you
