- 4 Aug 2007
- Wilds of suffolk
Thread for info, dates and timings, bragging on your points
Tricks and tips and documentation
etc etc
etc etc
43k points from one session
What's the story behind that?
Sync’d up his 12 on 12 off cycle.43k points from one session
I moved all of my planned energy usage that day into a window before the session started, it was approx 40kWh. Usage in that period is used to calculate savings.
so after that window you used zero energy???I moved all of my planned energy usage that day into a window before the session started, it was approx 40kWh. Usage in that period is used to calculate savings.
It’s an impressive amount of gaming I wonder how many others are also manipulating the system to that or greater extent?so after that window you used zero energy???
Do you have plans for your energy usage any other day?? and whats your normal day energy usage??
Sure, I know how the saving session points system works
What's the use which you shifted - car charging, Crypto mining....... ?
:: EDIT:: - I can see you see you added 40kWh now![]()
