** Savings Savings Savings - Take a look inside!! **
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Heres a selection of products from all over the catalog with some great savings for you to sink your teeth into!
:D
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £1.49 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £2.99 Inc. VAT
Only £1.49 inc VAT.
ORDER NOW
Yate Loon D12SL-12 120mm Fan - Black @ £2.99 inc VAT
A great reliable long lasting 120mm fan with near silent perfomance to boot.
- Model - D12SL-12
- Dimensions - 120 x 120 x 25 mm
- Voltage - 12 Volts
- Speed - 1350 RPM
- Noise Level - 28 dB (A)
- Connector - 3-Pin
- Bronze Bearings
Was £4.39 Inc. VAT
Only £2.99 inc VAT.
ORDER NOW
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM @ £10.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
- Super silent APACHE fans in Black Stealth colour
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £14.99 Inc. VAT
Only £10.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Mini USB2.0 @ £7.99 inc VAT
With the SATA QuickPort Mini, we introduce the little brother of the well-known SATA QuickPort.
The miniature docking station is suitable for 2.5" SATA hard drives and SSDs in the appropriate format.
The connection of the device is via the provided USB2.0 Y cable, which also simultaneously serves as the power supply.
The SATA QuickPort Mini has an LED indicator for power supply and hard drive access as well as an on–off switch on the back.
- Enables the direct connection of a SATA HDD to your PC via USB2.0
- Suitable for 2.5" SATA HDDs
- External interface: USB2.0 (max. 480 Mbit/s)
- Premium workmanship
- On/Off button
- LEDs for power and HDD access
- Dimensions: 95 x 55 x 45 mm
Contents
- SATA QuickPort Mini
- USB Y cable
- Manual flyer
Was £14.99 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Mini USB3.0 @ £8.99 inc VAT
The miniature docking station is suitable for 2.5” SATA hard drives and SSDs in the appropriate format.
The connection of the device is via the provided USB3.0 cable, which also simultaneously serves as the power supply.
- Enables the direct connection of a SATA HDD to your PC via USB3.0
- External interface: USB3.0 (max. 5 Gbit/s)
- Downward compatible with USB2.0 and USB1.x
- On/Off button
Contents
- SATA QuickPort Mini USB3.0
- USB3.0 cable
- Manual flyer
Was £17.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - Blue @ £4.99 inc VAT
CCFLs (cold cathode fluorescent lamps) are best suited for the interior lighting of PC systems. With an inverter they are connected to an unused 4-pin plug of the power-supply and can be used immediately. The CCFLs are 30 cm long.
- 2 CCFLs (same color)
- Self-adhesive pads
- 1 dual-inverter for connecting 2 CCFLs
Was £7.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - Red @ £4.99 inc VAT
Was £7.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - White @ £4.99 inc VAT
Was £7.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - Green @ £4.99 inc VAT
Was £7.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Kingston DataTraveler Generation 3 2GB USB 2.0 Flash Drive (DTIG3/2GB) @ £4.39 inc VAT
The reliable DataTraveler Generation 3 is ideal for your important documents, music, video clips and favourite photos that can be stored and retrieved in a flash. Available in fun colours by capacity, it’s a perfect fit for the office, home, school and wherever you travel. A well-built cap protects the USB plug and your data.
- Capacity: 2GB
- Speed - data transfer rates of up to 10MB/s read and 5MB/s write
- Dimensions - 65.68mm x 10.66mm x 22.37mm
- Simple - just plug into a USB port
- Practical - cap protects the USB plug
- 5-Year warranty
Was £5.99 Inc. VAT
Only £4.39 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £63.98 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 5 Years
Was £72.98 Inc. VAT
Only £63.98 inc VAT.
ORDER NOW
Western Digital Caviar Green 2TB SATA-II 64MB Cache - OEM (WD20EARS) @ £56.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Interface: SATA-II
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £69.98 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) @ £29.99 inc VAT
WD Caviar Blue hard drives are available with a multitude of available features to deliver rock solid performance and ultra-cool and quiet operation. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. These drives are the perfect solution for family and business computing.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £32.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) @ £39.98 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 250GB of high-performing, eco-friendly digital storage.
- Capacity: 1TB
- Cache: 32MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) @ £39.98 inc VAT
The F3 operates at 7200RPM with offerings of up to 1TB data storage capacity by using two 500GB per platter disks. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 1TB
- Cache: 32MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £44.99 Inc. VAT
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £54.98 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Edifier R1600T Studio Plus 2.0 Monitors @ £58.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
** boxes opened to include UK power cable, 100% new **
Was £69.98 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Logitech X-540 5.1 Speaker System (970223-0120) @ £53.99 inc VAT
Introducing the powerful Logitech X540 5.1 Speaker System. Strengthen your gaming with a harmonized soundfield that surrounds you. Get full, lush audio even from 2-channel sources for a 5.1 surround sound experience
The Logitech X-540 5.1 Surround Sound Speakers allows you to engross yourself in games and movies with a full 360° of audio. The Logitech X540 includes Matrix Modes which allows you to enjoy a 5.1 surround sound effect from 2-channel stereo source.
Frequency directed dual drivers provide a balanced, uniform sound without inconsistent even spots. Logitech have included real-time bass equalization in the Logitech X540 which maximizes bass response and minimize distortion.
Making life easier:
- The Logitech X540 speakers, mount directly onto most flat-panel displays with it Center channel LCD clip Just rotate the stands to switch from desktop to wall.
- Easily access power, volume, bass, Matrix Mode and your headphone jack on the convenient control pod which comes with the Logitech X540 speakers
- Enjoy your music, movies and games privately with the integrated
- Set up is easy just Plug and Play as the Logitech X-540 speaker system easily connect to PCs, CD and MP3 players.
- Total 70W RMS
Was [OLDPRICE] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Logitech S-220 2.1 Speaker System - OEM (980-000022) @ £19.99 inc VAT
Logitech S-220 Speaker System provides the rich acoustics with a high-quality subwoofer and two satellite speakers. A high-performance piano-finish wired remote provides the convenient access of volume and power controls, besides, its headphone jack and microphone jack give you more valuable usages, e.g. private listening, internet video gaming and conferecing.
- High class glossy satellite speakers with the ported subwoofer provides the full and rich audio performance
- Friendly wired control pod designed for minimizing the desk clutter
- The convenient wired control pod provides headphone jack, microphone jack, volume and power controls for adjustment easily
- Easy connection to PCs, CD and MP3 players and between satellite speakers and subwoofer
Was £24.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
OcUK Value SATA-II 90cm Red Data Cable (NLRB-307LOCK) @ £1.49 inc VAT
The OCuK Value SATA-2 90CM Connection cable with locking ends offers a significantly more secure connection comapred to non-locking connection.
- 1 x 90 CM Red SATA-2 Data Cable with 2 x Locking Ends
- Straight End Connections
Was £2.99 Inc. VAT
Only £1.49 inc VAT.
ORDER NOW
OcUK Value SATA-II 45cm Red Data Cable (NLRB-302LOCK) @ £1.19 inc VAT
The OCuK Value SATA-2 45CM Connection cable with locking ends offers a significantly more secure connection comapred to non-locking connection.
- 1 x 45 CM Red SATA-2 Data Cable with 2 x Locking Ends
Was £2.59 Inc. VAT
Only £1.19 inc VAT.
ORDER NOW
OcUK Value DVI to HDMI Video Adapter (DV-005) @ £0.98 inc VAT
OCuK Value HDMI to DVI Video Adapter allows the connection of HDMI-enabled components to DVI-enabled components. The HDMI-to-DVI Video Adapter consists of a female DVI connector and a male HDMI connector.
This allows you to connect an DVI cable to the female DVI side of the Adapter, and then connect from the Adapter to a HDMI enabled component.
- Femal DVI Connection to Male HDMI Connection
- Converts a component's DVI connector to HDMI for all-digital, high-definition video transfer from DVI enabled to HDMI-enabled components
- 1 Year Warranty
Was £1.99 Inc. VAT
Only £0.98 inc VAT.
ORDER NOW
OcUK Value HDMI to DVI Video Adapter (DV-006) @ £0.98 inc VAT
OCuK Value HDMI to DVI Video Adapter allows the connection of HDMI-enabled components to DVI-enabled components. The HDMI-to-DVI Video Adapter consists of a female HDMI connector and a male DVI connector.
This allows you to connect an HDMI cable to the female HDMI side of the Adapter, and then connect from the Adapter to a DVI-enabled component.
- Femal HDMI Connection to Male DVI Connection
- Converts a component's HDMI connector to DVI for all-digital, high-definition video transfer from HDMI enabled to DVI-enabled components
- 1 Year Warranty
Was £1.99 Inc. VAT
Only £0.98 inc VAT.
ORDER NOW
ENJOY!!
:D
