Hi All
I have settled on going for SB-E and not SB as I think this is the better long term option for me - although about £85 more in initial cost.
I have a Antec P182 case, GTX 570 GPU (will be buying a 2nd one later), and Crucial M4 SSD. All I need is the new mobo, CPU + Cooler, RAM, and PSU (as my currnet Corsair HX 620 Watt PSU probably wont be good enough for SLI).
As mentioned previously this is used mostly for gaming as well as everyday use but I do a bit of video work so the potential of extra cores down the road should help.
The spec I was looking at is:
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 - £224.99
Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard -£174.98
Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (KHX1600C9D3K4/16GX) - £66.95
Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK) - £92.99
Corsair Hydro H80 High Performance Liquid CPU Cooler - £84.98
or
Noctua NH-D14-2011 Dual Radiator CPU Cooler with PWM Fans - £72.98
I will be overclocking but want the queitest fan of the two.
Thoughts appreciated.
Thanks
or
Thanks
