SB61G2 SATA and IDE usage.
22 Mar 2005
Pamplona, Spain
SB61G2 Shuttle.
Can you use SATA and IDE hard drives at the same time on this shuttle?
I don't plan to use SATA and IDE both at the same time for booting up purposes, but I am thinking of using the SATA ports for a possible external backup solution.
Is this possible?
I have that specific model and although I haven't used IDE for a second hard drive, I believe there should be no problem supporting both a SATA and an IDE drive.
I am not aware of any limitations and on the BIOS there is a SATA option to enable both IDE and SATA in "combined" mode I believe.
