SBS 2011 buil tin antispam
Ish
Ish
11 Jan 2006
West Midlands
Hi
How good is the antispam feature of SBS 2011 and does it give you reports on messages that were blocked so that you can check if the spam level is set too high?
Hi Ish.
I've checked this out. It appears the slide Technet details for this have changed. Having installed the product and tested, there is no "built in Antispam" software other than the native stuff found in Exchange 2010. That may well suffice for a small company of few users, but I would be inclined to look at a 3rd party app.
Unfortunately, I',m not sure ForeFront for Exchange would run competently on SBS 2011. It would need to be a serious spec'd machine. Any of the other 3rd party style apps suitable for 2008 R2 should suffice. Trend Micro Worry Free, etc.
