Rob7865 said:Is that 25 licences also including the 5 you get standard with SBS>?
If not then that why!
ttfn
Rob
JonnyT said:I'm pretty sure what you're seeing is that the maximum number of users/devices (depending on which licence model you're using) which are concurrently accessing your server is exceeding the number of CALS (Client Access Licences) which you have installed on the server
Er, does the "Maximum Usage" not reflect the maximum number of Clients that have connected to the server - clients being Users or Devices based upon the licensing model chosen when setting up the server and the subsequent purchase of relevant CAL packs?burnsy2023 said:If you read my post above, the amount of users may exceed tha amount of CALs if your licensed per device, in which case he doesn't need any more CALs
Burnsy
And to reiterate my point about a 'grace period', Javier Gomez [MVP] in another post:"Maximum usage":
In Server Management\Licensing, the maximum usage means the most licenses
you have had in use since the last server reboot. That has no bearing
(other that showing you if you are nearing your limit) on the number of
currently installed licenses. The Maximum usage tracks the maximum number
of users or devices are accessing the server simultaneously by polling the
licensing service on the SBS server. Note that the Maximum usage number
might not reflect the exact number of licenses in use at all times, because
the licensing service is polled periodically rather than on an ongoing
basis.
> SBS stupid little license indicater says, maximum uses : 6
> doesn't seem to prevent the sixth client form accessing the server or
> outlook or anything.
Like I said... don't mind that counter. Just make sure you comply with
licensing.
SBS gives you some latitude with CAL usage enforcement... this means that if
you exceed the number of for a little bit you shouldn't have problems
(although is not really legal to do so). However, if you continue to add
clients at some point you *will* see it blocking the connections.
burnsy2023 said:Oh and a server only needs a CAL if there is more than one server on the domain.
