6-8 months is usual. They've overhauled the process recently and whilst that's supposed to shorten lead times it isn't doing at the moment. It could be whilst the staff involved get used to it.
Christ! Mine was back like 3 years(?) though...
Thanks guys. I guess as long as you're completely honest with everything if you miss something out it'll be fine.
In my situation the sponsor is a potential employer.
Had to go through a check when I got the job I am with now, however it was just to verify the stuff I had claimed on my CV was correct
(They verified my previous jobs, my education, any certification I had done, memberships I was part of), the fact that I was a UK resident and was permitted to work in the UK (passport check) etc etc.
With the security watchdog?
Was with a company called Veroscreening.com, that the company I work for use to do checks before employment commences.
Aha.
I've had to go through a similar check to the one you've just described alongside the SC stuff. Eek.
Should be fine, as long as you have nothing to hide and all the info you gave them is correct![]()
Yup
It's just the wait!
Do you have to be cleared before you start? by the time my start date had come, the screening still hadnt been cleared, they were still contacting me like a week after I had started asking me to send some further info
What if I actually turned out to be a serial murderer and they had let me start![]()
