Im getting in some areas about 25fps, is it really that poorly optimzed? Some places its smooth other places its nearly a slide show, lets just hope for a good patch.
no the game is fine, stop bitching about optimizations you know nothing about
Wow you really are a tool, if you cant tell me properly dont even bother.
what settings you running at? what res? what parts are giving you trouble? what operating system are you running this on? make a decent effort in your OP before crying about the optimization, if you want to wait for a patch then wait for it, but just shut up about it unless you actually want some advice
The game is poorly optimized, for ATI cards at least. Found this out to my cost last night - crippling glitches and framerate issues, and this on a less than 1 week old 5 and a half grand Alienware (Core i7 980x, 12gb Ram @ 1333mhz, 2x 5970's).
Quick search finds this to be a common problem, game swiftly uninstalled and exchanged for the 360 version this morning.
You assume the game is broken/unoptimized because its not running properly on your system - you called him a tool for basically pointing that out, giving you no advice because you gave him no details to go on in the first place. THEN you called him a child when he realised you're a dork but asked you for some info anyway.
Great job.
look the game is not poorly optimized for ati i have not had 1 single problem on my set-up with this game full stop i have completed it twice now and seen none of this stuff u are talking about. no major dips in FPS neither
stop moaning and get it round your head that it's probably your system cause lots of people are playing this title with no problems at all and just because your 5 and a half grand alien despair and repair can't handle it your blaming the game creators.
get a life will you things like this clearly **** me off
Get a life?look the game is not poorly optimized for ati i have not had 1 single problem on my set-up with this game full stop i have completed it twice now and seen none of this stuff u are talking about. no major dips in FPS neither
Try getting worked up over a daft game.
yeah but he could have pointed out to him a little better dont you think
