Scanner and dpi - confused!
26 Feb 2004
China (Qinhuangdao)
I'm looking for a new scanner. I had decided on a Canon 4400F, but they're twice the price out here. I might possibly get the LiDE 25, as they're much cheaper here than UK. But I'm confused by the resolution.
The spec says 1200x2400 dpi optical resolution. So to me that means 2,880,000 pixels per square inch? Is that correct? So if scanning a 6x4 inch photo, (i.e. 24 sq.inch) I will get a final resolution of 24 x 1200 x 2400 = 69 megapixels.
Than can't be right, can it?
